hahahaGet outta this thread!!![]()
is it just me who thinks the gloss metal band is absolutely revolting?
Mine was from Very and it had a red label on the outside plastic wrap saying do not open if you want to return the phone.Vodafone order has arrived so soon as I get home I will be taking it back for a cancellation although I’m half tempted to open it up and see what it’s like.
Not sure if that will affect my return policy though???
Though screen the same?the 12 pro has a better screen than the 11 pro so its probably drawing more juice right
I guess every company has different criteria but when I checked with Vodafone they said you can open it up, see if you like it and if you do not then take it back. As long as it has no damage in it then it’s fine.Mine was from Very and it had a red label on the outside plastic wrap saying do not open if you want to return the phone.
That might be online policy but taking it back to store might be different ?I guess every company has different criteria but when I checked with Vodafone they said you can open it up, see if you like it and if you do not then take it back. As long as it has no damage in it then it’s fine.
