They do not attract the same buyer. It's silly to say they are interchangeable.
It's you that's drawing reference to both models to somewhat push the validity of whatever point you're attempting to get across. It's either the 8 series or the M8C you are speaking of, and in trying to be correct, you're moving the goal posts by mentioning both.
An M4 buyer will not suddenly consider an M8.
Factual or anecdotal? Happy to concede if you can provide any factual evidence to support this, although I would agree that an M4 buyer wouldn't suddenly consider a
brand new M8.
You are trying to make the differences sound trivial by giving a separate outlandish comparison of the 1 series and X7 as the yardstick of being different. Completely different prices, but to you they are both expensive cars and are therefore similar.
I've already pointed out the fundamental basis by which they are comparible, the stark variance in price is only apparent when comparing brand new with brand new, guessing we're going with the £125k M8C then?
Unless there have been any fundamental changes since the release of G15 to the extent where you are missing out on something so significant that serves as a justification for making buying a brand new one essential, I can't see why an approved used M8C wouldn't be considered as an alternative as this isn't at all much more than a G82 M4.
Given the price of both in relation to the avg spend on a car in the UK, I do stand by my comment that objectively, neither are cheap. If by your standards they are in fact cheap, then well done for being successful enough to enjoy such things.
Time for a coffee, Fox this is your fault.
