Or pci-e 4.cant leverage infinity cache that does not exist on intel can you?![]()
you hit itwith more power it's going to go a lot more hence the price tag .. i'm sure a 5800 at 350w will go up against the 3090 ... amd oc crown again ..You are aware that unlike most, when AMD say "boost" clock they mean "this is what it can sometimes achieve for a split second under ideal circumstances"?
"game" clock is what most refer to as boost clock. That is to say the average clock maintained under boost
no, but they will take your money anyway.
I told you!!!!! they smashed it, im seriously considering the 6900xt also
It very well may do. That remains to be seen.you hit itwith more power it's going to go a lot more hence the price tag .. i'm sure a 5800 at 350w will go up against the 3090 ... amd oc crown again ..
You are Wrong. It's not limited to 2015MHz.
spoken like someone eagerly awaiting their 3090
Trying to defend their purchase
You didn't need to tell me. I knew what was going down. Literally they said to the cpu guys sort this mess out... Guess what they did.![]()
I see you have a 5000 CPU Grim? Should have waited instead of two feet into the 3090![]()
So the GPU has features that only enabled when Zen 3 is detected? How unconsumer friendly of AMD, learning from Nvidia and Intel everyday - I like it
Wrong, it's not limited to 2015Mhz (charts provided in previous reply to you)2015MHz is monstrous now?
You are still wrongI mean, sure if you want to claim that the game clock is actually the base clock go ahead but if you remember the 5xxx range that's clearly not the case
Tell me I'm wrong all you want, but when Steve at GN is saying the exact same thing as me I'd be inclined to feel somewhat validated
And seriously, turning this into a "haha you just have buyer's remorse cope harder lolololol" thing? Very classy
And the icing on the cake, no nvidia price drops.People wasn't expecting this shake upThe best thing we all win here.
What are expected UK prices?
(snip) but when Steve at GN is saying the exact same thing as me I'd be inclined to feel somewhat validated
rage mode high power target,eg msi afterburner power limit to say 110%Folks what is "Rage Mode" and this "Smart Memory" thing they refer to in the benchies?
Am I reading it correct that basically 6800 is on par with the 3080 and same with 6900 vs 3090? (ish?)
As I said earlier, AMD must be happy with their current small amount of marketshare because these cards are going to do nothing to change that! Tbf to them though they are biiiiiiiiiiig chips to produce and no doubt expensive!! I doubt they were expecting the 3080 to come in so reasonably priced as it was.
