- 6 Jan 2013
- Rollergirl
Could anyone recommend a floor tv stand to use?
What do you mean by a floor TV stand?
Yes I suppose when your paying so much for a tv, it's better safe than sorry and get the right stand.
The FT-S1602MB has an iron base if you're concerned about the glass shattering
Can I get your thoughts on a potential set up please?
I'm getting the CX in a few weeks. I'll be using it only for gaming and media content... for all other PC stuff (i.e. web, work, study etc) I'll be using a 27" Dell. I'm just not sure of the best way to set things up. I have a deep (~1m) desk and was thinking of wall mounting the CX, and then getting an ergonomic desktop mount for the Dell, to the left of the TV. That way I could have the 27 incher in portrait mode beside the LG when gaming, but then be able to pull the Dell into position in front of the TV when I need to get my productivity on.
The big problem with this is that any speakers would have to be positioned asymmetrically. I'm not sure I'd even have the space for speakers. Maybe a soundbar would be a better choice? What kind of layout would you go for in this instant?
Tempting. My current client has a 30% discount on RRT for employes from LG. I'd prefer a 40'', too bad they start at 48''.
Also worried about PWM, do these TVs have something like a DC dimming option?
Chaps just to clarify, if one were to order this now and it were to later go on sale (thinking about black friday), am I correct in assuming retailers like JL will refund the price difference as it's now within 28 days?
Guys my 3070 is arriving later today and I am downloading the latest firmware 03.11.25 now (it doesn't come up when I try to update from the TV).
Have any of you successfully installed this firmware manually and it's working? Don't want to **** it up.
Cheers
Why do you need another monitor the CX 48" should be fine for the other pc stuff too, I just use one CX 55" for everything and I don't use soundbar or speakers I just use headphones to block out the noise around me + don't have to listen to the wife this way Lolthe CX 48 isn't that big so wall mount it and then put the speakers under it or at each end of the TV the TV sound is good enough with good bass unless you like the sound to be much higher when gaming on than go with a soundbar the choice is yours
So you use headphones plugged into your pc, right? The problem I can imagine happening (i don't have the tv yet) is that anything HDR or DV has to be played through the native app (as opposed to the PC), so when that happens, you have to redirect your sound back though an amp or DAC? Am i correct?
I already have the 27", and there are multiple reasons to use it along side the CX. Headphones will be used the majority of the time, but it's not possible for me to use them all the time.Why do you need another monitor the CX 48" should be fine for the other pc stuff too, I just use one CX 55" for everything and I don't use soundbar or speakers I just use headphones to block out the noise around me + don't have to listen to the wife this way Lolthe CX 48 isn't that big so wall mount it and then put the speakers under it or at each end of the TV the TV sound is good enough with good bass unless you like the sound to be much higher when gaming on than go with a soundbar the choice is yours
Spoke to JL today who said they're ordering 60 more units tomorrow that should appear online in two weeks or so.
Saw some more stock appear today but didn't get the email alert :/
So this tv has jacks out for head phones? I don't have BT headphones. I only have headsets either with the 3.5mm or the larger size. How is the sound quality coming out of the tv directly? When headphones are plugged in are the speakers muted?If I'm watching via native TV apps then I use Bluetooth headphones paired with the TV.
Finally managed to bag a RTX 3090 the other day from overclockers so can now get the full benefit out of my 48"CX![]()
