AMD Zen 3 (5000 Series), rumored 17% IPC gain.
Status
Not open for further replies.
2 Feb 2018
Exeter
Nice paint job Zeed. :)
Although they have fixed the latency issue within the chiplet in Zen 3, where each core in a chiplet can now communicate to each other, without leaving the Chiplet to do so, with the likes of 5900x and 5950x, communication will still need to be transferred via the IO Die when communicating with each chiplet.
In an ideal world, if everything was housed in one chiplet, this would massively reduce latency. Maybe to come in future Zen... (But AMD did say, doing it with chiplets, and separate IO die makes it very cost friendly to mix and match new chiplets to test new vs old architectures on the same piece of silicone.
15 Oct 2019
Uk
Anyone know if per core overclocking works on these chips?.
You could do it on Zen 2 with ryzen master but would cause some cores to just sit at base clock speed.
Permabanned
15 Oct 2011
Nottingham Carlton
@mikeym @LtMatt gotta love informing idiots when they got no clue what they are talking about :)
@true_gamer added more so maybe with 1 brain cell he can comprehend difference between xen 2 and zen3 chiplets and where performance actuially came from and why its not as massive jump in multithread from zen2
28 May 2007
Thats exacly why Zen3 is good in
ITS NOT MICROSOFT ITS FLAWED DESIGN only stupidity here is from You blaming microsoft for AMD's design decisions.
Do you understand why that design was XXXX now ?? Data inside Chiplet on ZEN2 is jumping over IO DIE not inside Chiplet adds extra latency adds heat reduces stability and so on.
Even if You force software to stik to using selected cores you are still gimped by this design.
Stupid like a fox maybe. TBH bolting clusters of 4 cores together over IF is also a stroke of genius. The alternative is a ring system and we have seen how that scales.
Caporegime
12 Jul 2007
United Kingdom
Calm down Zeed, no need to go around calling anyone morons or idiots.
30 Mar 2012
g6HkD4y
Here before its released - lol
Permabanned
2 Sep 2017
This is wrong.
The CCD on Zen 2 has 2 quad-core CCX which talk to each other via the IF structure on their CCD, and not via the IO die which sits independently nearby:
https://hexus.net/tech/news/cpu/131549-the-architecture-behind-amds-zen-2-ryzen-3000-cpus/
Status
