- 21 Jul 2005
- Officially least sunny location -Ronskistats
Liking this, need to see Toxic version though![]()
It's really that simple. Nitro cards tend to OC better and offer better cooling then most other AIB's. Typically they are priced reasonably. As a tier they are the highest Sapphire offers. Sapphire's Toxic sku is more of their mythical unicorn tier that is allegedly designed to beat Nvidia's offerings do to it's higher then normal OC'ability. We haven't seen Sapphire release a Toxic sku in years.Can someone remind me of the different Sapphire cards. Generally speaking are the Nitro versions better than the pulse or vice versa?
Yep, this is where its at, Sapphire Nitro+ cards have always been bang on in terms of performance and cooling. This will be my first choice.
Thank you for that breakdownIt's really that simple. Nitro cards tend to OC better and offer better cooling then most other AIB's. Typically they are priced reasonably. As a tier they are the highest Sapphire offers. Sapphire's Toxic sku is more of their mythical unicorn tier design to utterly beat Nvidia's highest sku in that tier do to it's OC'ability.
No Problem.Thank you for that breakdown
Nah used to be the top end Sapphire GPU, Nitro+ looks to have replaced it, but i heard a rumor of a Toxic and this time round could be an AIO cardIs that the liquid cooled SKU?
Pretty much what East Coast said, last Toxic i had or saw was the 6950, was an awesome card.Perfect. Thanks very much.
Looks like I'll be keeping an eye out for those cards then.
290 i had their Tri-X and Vapor-X both solid, the Vapor was their top end card.
They have been using Pulse, Nitro and Nitro+ for a good while now, that Nitro+ i guess replaced the Vapor-X or Toxic tier card.
Pretty sure they done a Nitro+ SE or something recently too, generally Sapphire cards have dual bios and their Trixx suite is very very good for OCing, zero RPM fans that can actually be easily removed and replaced as well, which was a design decision of theirs
Take a look at their Trixx features, the suite is very very good
https://www.sapphiretech.com/en/software
Can switch bios mode from desktop and it has RIS built in etc, plus Nitro are RGB if thats your thing so can change the glow etc
Ok thanks, I'll take a look shortly.
I've got the pulse Vega 56 so was looking to get something of similar standard. I really like my current card so was wondering the different models.
Once things settle, I'll be getting another Sapphire card so I'll wait and see what each one features before deciding.
Same, pulse vega 56 so anything on par or maybe Nitro is the way. Would love to see a liquid cooled offering but the premium will prob be too much on the 6800XT.
And a tuf, but I'm not sure I can trust Asus based on last two amd gen
