He also claimed there would be plenty of 3070sAccording to more's law is dead channel the amd stock will have a number, l
Any pictures of the aib cards yet?
Ummm the 5700xt was never geared/marketed as a 4k card?
It was very clearly said to be a 1440p card...
That wasn't quite what I was getting at, I want to know why AMD GPU's basically die when the game tries to use more memory than the card has in VRAM cache? Nvidia's cards also lose performance but only a bit while pushing extra memory into RAM, the 5700xt still pushes data into RAM but he card loses like 70% of its performance.
4K at only 1800Mhz for a 5700xt with is really low frequency.
1440p results. And it beats a 2070s.
I'm not sure what the problem is suppose to be.
So in an interview today about ray tracing, Nvidia disputed any notion that they are forcing CDPR to use RTX extension for ray tracing to lock AMd out of Cyberpunk 2077
people were concerned because the developer said ray tracing will not work at launch on amd cards.
min that interview Nvidia refuted they caused this, they said Cybperunk uses the normal DXR extension not RTX so any gpu that supports DXR can use the games ray tracing - other games that use DXR are shadow of the tomb Raider and control and others. If Cyberpunk doesn't let big Navi do ray tracing that's simply because the developer or AMD itself is blocking it for some reason otherwise ray tracing should work on day one for big navi
https://wccftech.com/nvidia-interview-discussing-ray-tracing-support-and-proprietary-extensions/
I probably have missed that part since my targeted cards were top 3080 and 6800xt. Let's hope they won't go extinct in 2 minutes, and have a full 5 minutes to buyHe also claimed there would be plenty of 3070s![]()
Ray tracing will probably be not optimized for amd at launch, both pc and consoles. Also with the amount of ray tracing going on the performance will be probably undesirable without super sampling. Thing nvidia is marketing, rtx+dlss, available for wd legion as well, despite that game being a total mess when it's coming to optimization, as usual for UbisoftSo in an interview today about ray tracing, Nvidia disputed any notion that they are forcing CDPR to use RTX extension for ray tracing to lock AMd out of Cyberpunk 2077
Yep, there will be 10 cards available![]()
Use the cryptic lingo... "small amount"![]()
Any news from Gibbo about how this launch will go down? the last nvidia launches have been a complete meltdown for me on OC and I dont want to get c-blocked by the weak website again
Hope so...and good luck.I probably have missed that part since my targeted cards were top 3080 and 6800xt. Let's hope they won't go extinct in 2 minutes, and have a full 5 minutes to buy
