- 21 Apr 2007
that's a really good result tbh.... even at 4000MHz you'd likely have to loosen the timings and that's assuming you'd make a 2000Mhz IF FCLK1.5v daily for 3800MHz @ cl14 with IF 1900MHz
If it benefits anybody looking at the out of stock 2x16GB set, I asked in the CS section if the stock due date of 13/11/20 was still looking good and was told it is still expected.
I guess the stock never arrived. Was hoping to order a set today but its still saying due today![]()
I ordered the day I posted and got it delivered Wednesday. I did check the store yesterday and thought it strange they hadn't updated it.
Hmm that's even more annoying now. Didnt order cos it said no stock. Got a x570 Tomahawk and 5600x sat here waiting on ram....
How is the ram running? Tried overclocking it yet?
Same. What’s next / first thing on your list?All I've done so far is set XMP and set up windows. Not tried any nore testing yet or overclocking as only just getting used to having an AMD system.
Do you need to disable XMP if overclocking memory or tightening timings? I changed PBO from auto to enabled and it seemed to clock lower than when on auto
Similar, i7 4790k from 7 odd years ago.At the moment I've not much of a clue. I'm coming from a Sandy Bridge system from 2011 so things have changed somewhat.
Still making sure Windows is how I like it before venturing any further. Also waiting to buy an new GPU to be able to make the most out of it, so atm more happy just to make sure it's all stable at stock
Bios and the whole process is so much easier now! Thinks never used to work for me, this time everything working perfectly so far. Ut seems overclocking cpu isnt worth the effort but may change ram timings to tighten timings at 3600Mhz
I gamed for an hour last night and mine was stable at stock (Ryzen 5 3600)
2080Ti overclocked with the same settings as used with the 4790k.
Whats the new / best stability test for Ryzen and RAM? Probably not Prime95 any more
Think you’re right about not having to touch CPU.From my limited reading so far I think I'll also leave the CPU alone and twaek the memory, as it seems this RAM demands to be overclocked and we'll see a real world difference especialy in gaming. I assume that can be done without touching the CPU as I haven't read up on this Infinity Fabric and how that works yet.
so far I've only looked at Cinebench 15 and ran that a couple of times to check temps, jsut to mke sure my AIO was working Ok.
RAM wise im just not sure if you change timings if xmp needs to be disabled or left on. More reading but so far so good
With your step one settings, 16 16 16 16 32 48 288, are you having everything else on auto or are you setting up the 2nd and 3rd timings as you have done above in that post? Currently trying to start your process but I'm getting two single errors in 250% in one of the windows for memtestpro.So for example...
Thanks, 1.2v SOC was the auto value but I've dropped it down along with the other voltages using your previous posts as a guide and upped the ProcODT to 60ohms.Your chipset and vddg voltages seem awfully high for 3600... May be worth sorting those out first before stress testing, memory timings will have little effect on those so you can tune them down before you do most of the work. Your memory voltage is a little high too for the speed and timings, it shouldnt need to be that high at all unless you have got unlucky with a stick that doesn't overclock very well. I'm also surprised to see your ProcODT value at 53.3ohms, normally I would expect to see that at 60.
YepAre you running 4 sticks there?
Thank's for your next suggestions and in general your write up's in this thread, some great info and explanations. I'll try them out and chase things down later.
Got the 2x16GB 3600Mhz kit ( https://www.overclockers.co.uk/team...00c16-3600mhz-dual-channel-kit-my-002-8p.html )
@ CAS14 (14-14-14-28-42) Set at 1.45 volts to be safe.
Is it worth leaving it at these timing or just leaving XMP enabled? (Ryzen 5 3600 CP![]()
Is it worth leaving it at these timing or just leaving XMP enabled? (Ryzen 5 3600 CPU)
Sure. Black values on the left are 'calculate fast'Can you post your settings from the main tab, want to give these a go as I have the same kit.
Hey, just wondering if you have any clue on this behaviour. I've used a more aggressive fan profile and dropped temps and 16/16/16/16/32/48/288 is now perfectly stable (with tWCL 14) at 3600mhzNo worries, good luck dude!
