It's the red lips one, Mine is the FTW3 Gaming. Will do, I found a site that does custom cables for this case in particular but unsure if we are allowed to post the name here.@Wip3d Dude looking good. I'm a little biased as I have the same cooler and GPU haha. Let me know what lengths for cable you go with. I've been meaning to get some to clean it up a little. Mainly for the (3) GPU 8-pins as my 24pin and CPU cable tucked away nicely.
Did you get the refreshed FTW3 Ultra with the black lips instead of the red ones?
I came here directly after watching m&m to see your reaction lolI'm half way through watching it but kids have other plans![]()
Last night I played Hunt Showdown for a couple of hours, the game stresses the CPU more than most for some reason I've noticed before it can get quite hot, on the NH-U9S with two fans I remember it hitting 75C after two hours
Last night I could hear the Big Shuriken revving up quite a bit, not annoying but louder than than Arkham Knight which is the only other game I'm playing at the moment and I thought temps were going to be high
Checked the temps after turning the game off and 71C peak temp, really happy with that, going to put a P12 on it and see how that performs as I have a spare couple of P12s in the loft hopefully it takes off a couple more degrees and is even quieter
That’s good to hear. Finally settled on a cooler.
As for me I’ve changed my cooler from the Mugen 5 to the ID-Cooling SE-234 and it actually performs better than the mugen 5.
Will get some pictures up tonight.
Yeah I think so
Which CPU and side panel? I read that cooler won't fit with TG panel
Nice work, 5800X is a hot CPU from what I've been reading so maybe those direct touch heat pipes are playing a part there
I could have sworn I read that cooler wouldn't fit with the TG panel I was on the verge of ordering one because they are so cheap but I'm happy with mine now
I'm tempted to order some more scythe fans one RGB for the cooler and a couple of vanilla ones to replace the P12 exhaust because I prefer the sound of the scythe fans, the P12's seem to make an annoying whine between 800 and 1100 rpm for me and I can't seem to avoid it
Hovering over the buy button, must resist, send help
Do it do it.... looking at the 1800rpm ones?
Sorry im being daft, are you saying your happy with the Big Shuriken 3?
Thats the one im settled on getting with the non glass panel, is that the temps your getting with the glass panel on?
