- 18 Nov 2020
Sure please see below.
Apologises in advance, I have a ****** old phone so pics wont be super high res!
connector
https://imgur.com/MV6yRlJ
pins
https://imgur.com/qf57O54
In the pins pic you can see the bottom left pin looks like its come loose of the metal frame its hanging on and in the top right the entire pin is mushed (and i've not even applied any force when trying to connect the power cables).
But from the first picture I cant see is the new adapter, check for it trow the blackplate, and see if you got that block
Like this:
You should see that from the red mark coming out from the power box a little bit.
And about the pins, I see them ok, I dont know try to put them in place with a screwdriver should be good to go
They will test it before send it so perfect : D The seller will manage the rma of the faulty card so everythin' good.
