I've treated myself enough this year with a new card, new blocks, new rads, new cpu and extra ram! Well into 2k worth of stuff lol!
I'll take a look at clocking my ram abit faster though last time i tried 3600 with looser timings it just bsod on me and screwed up my rgb on the memory.
I'm limited to 370w on mine as it only allows upto 104% but it seems to give it plenty enough to overclock upto 2185mhz. I reckon an unlocked power target to 114% would easily see it over 2200mhz!
one one treat wont hurt LOL, yeah ram can be a bit tricky to oc tbh, but if done right the payoff is great
(samsung b-die makes ram oc way easier, if on microm e die well your out of luck its doable but you need to chance loads of settings and in the end it may be worse)
oh yeah your on a palit card right, did you have a look at the bios flash guide i posted, the gigabyte bios i recomended had a power target of 110% which should allow upto 400w ish which as you say may allow the card upto 2.2ghz or more
