Have you set the display section to show the Gsync On logo?
I think I did this. One thing I didn't do was try the freesync engine on ultimate. Only tried standard mode.
can your monitor display current refresh rate/frame rate.? as this is the easiest way to tell if variable sync is workingIt all enables OK, I just don't see any difference when running the pendulum demo.
You need to do ultimate
if working the refresh rate will change with changing framerate if not it will be stuck at chosen refresh rate.
Good timesIt's happening!
3080 FE order picked.
It's happening!
It's happening!
I’d get a new case of you really want a 3080, those sandwich style ITX cases are not well suited to a founders edition and run very hot as they can’t vent the air from the pass through fan.
Either way you need a different case so might as well keep the msi which you have.
Good times
Thanks guys, I'll soon be joining the Elite Squad.Nice!
I think the telegram one was consistent for me.
Yeah, it does. Oh and you can thank me as I am the one who showed himJust changed the Conversations setting, will it let you now?
