Ordered the 8/8/16/512 for delivery mid December.
Good choice.
March next year at the very earliest.
It won't be soon that's for sure or they would have announced it at the last event with just an extended lead time (like they did with the iPhone 12 Pro Max).
So, I now have my MBP in to replace the MBA.
obviously very similar machines overall, slightly heavier though. But happy to report that I also haven’t heard the fan come on yet.
Oh dear, sounds like you’ve had water ingress and that’ll be £1700 to repair.
Not with AppleCare+ of course![]()
Joking aside that is my only concern with jumping into the MacBook ecosystem. Some of the stories I've heard about Apple's aftercare, especially with the misnomer of Apple Genius, have me hoping nothing goes wrong with this machine once it's out of warranty. I'm not talking about expecting free repairs, but accurate diagnosis is a must. Anyone can sell you something, it's how you're looked after in after sales that gets you back.
Evening
So 2 questions is Apple care worth getting ?
And i assume my son could plug an external mouse via usb to use in stead on the pad ?
Still debating the base unit 8/7/16/256 for homework and a bit of coding he's learning and streaming on twitch
Thanks
What is he streaming?
If it’s games, most aren’t mac compatible and a windows machine is a better option. 256 storage is very small if games are also a thing.
I’m sure people will not be gaming on these.
That will be a solid machine with the 16GB RAM. Storage is fine unless he plans to store a lot of files locally.
You can use a dongle to connect a USB-A mouse, but may as well get a bluetooth mouse and free up a port.
This accessory is worth while as well, instead of buying separate dongles.
Anker USB C Hub for MacBook, PowerExpand Direct 7-in-2 USB C Adapter Compatible with Thunderbolt 3 USB C Port, 100W Power Delivery, 4K HDMI, USB C and 2 USB A Data Ports, SD and microSD Card Reader https://smile.amazon.co.uk/dp/B07YZ...i_fabc_dlC_m4NWFbSA1YEGK?_encoding=UTF8&psc=1
What I’ve found is that when the system is pushed and memory is low it starts to get choppy. I presume because the memory is shared with the integrated GPU so it has a knock on effect on GPU performance.
