This guy here tested for the same thing. Seems to be common result, single score around 610.
He tried different Bioses, Windows update, nothing. Ended up with no answer yet.
Could it be too aggressive LLC? Try to set it to maximum vdroop (resulting in higher voltage at low single core load and lower voltage at multicore)1. Higher multi core results directly corelate to lower single core.
Impressive latency, but what is wrong with the bclk? Why does it show 98.5 in all 3 aida screens?
Is there such thing as drooping bclk under load? Because that would explain lower than expected performance
I have MSI so no its not just Asus. My single score in R23 is 1605, in R20 my highest was 635 but normally around 625, should be higher.Some topics around internet popping up that it might be ASUS bios at fault, hopefully it'll be fixed with December update.
From my extensive testing nearly one week now, there are few things that stand out:
2. CPU seems to be run hot and boosting lower when temps go above 80c. Looking to build custom water loop now.
3. Undervolting by 0.075v yielded nearly same results.
4. Running at 1800,1900 or 2000IF and 1:1 is no issue. Ram speed and latencies seem quite impressive at max IF of 2000MHz.
IF=1800
IF=1900![]()
IF=2000![]()
5. Windows 10 type, version or freshness does not affect performance. Upgraded to Windows 10 Enterprise Version 20H2. Exactly same results as Windows 10 PRO Version 1909.
