- 8 Dec 2020
Thank you!!!
That gave me another boost . Asus does suck ass bios wise, when you have to disable "performance improvement options" to get better performance
PBO Enable motherboard limits, CurveOptimizer set to -15 on best cores and -10 on rest, +100Mhz, Scalar x4, LLC set to default, voltage set to auto, Performance Enhancer - default, PBO Fmax - disable.
PBO 300/220/240 limits, Curve Optimizer set to -15 on best cores and -10 on rest, +50Mhz, Scalar x10, LLC set to default, voltage set to auto, Performance Enhancer - default, PBO Fmax - disable.
And finally some good results without overclock or voltage. Cant wait for the cpu block to arrive to see what this CPU can do with a sub ambient chiller cooling
I’ve been having the same issue with my 5950x since release date on a asus crosshair VIII formula tried all the bios’s released since and am still having low single core score and can’t for the life of me find the mentioned “performance enhancer” setting anywhere in the bios. Has it been removed?
