Any of the fine inhabitants of this forum have a H1 and a set of callipers?
I don’t, but this seems like such an easy fix by ordering some nylon screws but I don’t know the correct length or diameter.
edit: corrected bad spelling
Just read someone on reddit say he used M3 Nylon screws to make the change.
You need some bolts for them too FYI!Legend. Cheers. I’m going to order some and see if they work.
I've ordered some too - from eBay. I'm going to do the zip-tie mod in the meantime.
Tbh I think this might end up being the solution. I need to switch my riser for the new one anyway just not got around to it.Just replaced the screws with zip ties...took minutes and feels solid.
Hang on the case holes aren’t threaded?
The screws are self tapping screws. Sorry if you made a wrong order! I should have been clearer.
TBH, just use zip ties. I don't think I'm changing mine over until NZXT send something out (whenever that is).
Whats the best thing to a fire hazardous case?
A wood panel!!
I have the same front but the magnets glue used are awful and the magnets come off. Any idea what glue to use for the magnets ?Finally put on my new aluminium powder coated front panel. Loving it so far. The ventilation cutouts align nicely with the rest of the case. Drops 5 degrees in peak temperatures when running Timespy with fixed fan speed (5700xt).
