How you getting on buddy? Much gaming yet?
I bought Death Stranding today so gonna give that a whirl. It also has the DLSS so if I get a moment will check this out and see if it blows me away..
Morning all.
So my 3090 FE has been a roller coaster for sure...
Recap, my EVGA 1200w PSU that has already had 2 x RMA in 2 years needs a 3RD!!! It just cant run a 3090 FE, trips out soon as ANY load in the card happens, I even had JUST the Card/MB+Nvme running still pop!
So plugged an old 500w psu into the second rail on the 3090 fe and (mostly) not had a problem, only 1 pop last night after crazy clocking, awaiting my 3rd RMA and PSU's to actually come in stock looking at a
Corsair HX1200i or 1000W Corsair AX Series AX1000, what comes in stock first I guess, also torn the extra 200w slightly less efficient but has more amps on the rails vs digital delivery less amps and less watts.... not sure atm.
The card after many many many hours watching my son play Rocket League at 165fps g-sync 20% usage.....
I got to play eventually!!
Under volting seems what my card likes, no matter how much you try and brute force the voltage or amps it just doesn't allow boosting.
To give an example I could get 1980mhz @ 843mV but only 1650mhz @ 981mV.
The way the card boosts as well is kinda weird I'm guessing some sort of hidden algorithm that you have to dance around on your own cards.
Like I could set a given Mhz+mV and it would boost 2 bins higher and crash or I could set the same mV+ slightly higher or lower Mhz and observe a different boost behaviour or even an almost locked Mhz, so finding the sweet spot on your cards going to be time effort and learning where the girl likes being tickled
Im in no way an expert or going to set records but with late last night and early morning testing Im happy with what I achieved so far.
Stock Port Royal I was seeing boosting to 1850mhz and scores around 12600 with temps hitting around 68c.
My best Port Royal after tinkering and it's stable as in can run a burn test for an hour or play games on it, scored 13918 Core @ 2010Mhz + 900mV (undervolt), memory +750,
56 °C!! Stock cooler custom fan profile never went over 50% which is quite!
https://www.3dmark.com/3dm/53925680?
Just ran the Horizon - Zero Down benchmark, all settings max it floats around GPU 70% usage, 270w draw and 51c... 120fps locked.
I mean for a stock card its pretty bloody good im pleased, I cant see me getting more fun for £400 more for a Stix OC, rather put that into a custom water loop.
Hope this helps.
