Got this board last week, it's my first AMD build since the old XP2500
Stuck in a 3700X as a stop-gap, 5600X will be here this week.
Got a 1080TI on a Kraken AIO still, when there is stock of the 3080 ill upgrade that.
The build was very easy, great layout, easy to work with.
The annoying thing with this new build is because I went from a mini ITX board to this. It means I cant fit the GPU AIO on the top as the PCIE slot is lower. Tubes aren't long enough. Its meant I've had to mount it on the front, and ditch the 360 rad I was using to cool the CPU, and replace it with a smaller one. So the 3700X temps are sat at 40-50 rather than the 30-40 they were on the 360 rad.
