Please do a run of Cinebench R23 to compare settings etc...
Case fans at 50% and NH-D15 at 1200RPM at 80c.75c idleIm getting 75c on my 5600x (idle) with the stock cooler lol, is that normal? im waiting on a aio atm.
75c idle
Are you sure there’s a cooler on there?
Really though, it must not be seated right, has no paste / way too much or your pc is in a sauna
Cooler pre installed in a bundle and 70c idle!? It must have either been knocked about in transit and become loose / fallen off or built by monkeysHaha ye thats what im thinking, i got the bundle with the cooler pre installed so i decided to just wait till i get my aio, i think they scuffed it, my case is pretty alright.
Did you take the plastic off before mounting it?id imagine the latter.
Yes, if you want higher all core frequency. At stock your performance is right where it should be.
What are temps like as the all core does seem low, should be boosting to around 4.5-4.6 all core at stock.
