I went straight to F30o
Where from ?Just got my 5950x ordered and arriving tomorrow
Will be a straight swap from my 3900x on Aorus Master X570 - is it best to go F30 to begin with then try F31o or just straight to F31o in everyone's experience? I have a bit of a strange RAM setup - 2x16GB plus 2x8GB (all SR)...
Well I managed to get a 5950 for £750 so looks like I will be selling my 5900xyeah why not!![]()
Where from ?
Just had my new system arrive as long overdue for a new one.
I've got a 360mm AIO from Corsair but it can't cope with 5950X all cores at 4.6GHz / 1.3V which is very disappointing even at 100% fans, and crashed during a handbrake test even though the overall CPU utilisation was around 65%.
If it wasn't for thermal shutdown, I reckon I could run this at 4.7GHz all core 1.33V as that seemed stable.
Might just be a bad paste job on a core, as the overall CPU temp was reported at 75C. I've had to drop this to 45x multiplier at 1.275V just to stop thermal shutdown at high load.
I ran my Intel 5960X at 4.4GHz / 1.275V which was probably pulling 100W more, on a 240mm radiator, so can't see a 360mm AIO being so much worse than this.
I'm guessing that I need to re-apply thermal paste / re-seat cooler? Seems to be quite a difference in max and average temps between CCDs and too high on CCD1...
See if you can balance it by changing mount pressure.
witb those settings the 5950x will be pulling 300w+
It's not the AIO, it's the cpu. I've got a h150i and it can't keep temp down at 1.3v manual. Managed a 8700k up to 1.425v no problem. Using pbo / curve / auto boost like the chips meant to there's no issue with the h150, temp doesn't go above 80deg. Manual oc puts out a hell of a lot of heat.
What Mobo?
Also please could you post your memory tab in Cpu-z
Bit strange, running CB R23, they're both maxing out about 68 degrees centigrade.
I'm assuming it was when I was running MSFS or Cyberpunk that the anomaly occurred. Might keep an eye on it, have also updated HWinfo to the latest just in case.
It's a bit of a headache just getting PC out to work on, then would have to remove GPU (pain in itself as I have to remove RAM to get at the release), then remove middle CPU cooler fan to get at mounting screws!
