Man of Honour
- 18 Oct 2002
- West Coast of Scotland
Very interesting, and I like the way you can modify the picture dynamically using the camera if you so wish. Need to investigate further
What do you guys mean by worm issues?
I've always just plugged in the SD card and imported the RAW files from my X-T20 straight into LR without any problems.
Hovering over the 35mm F/1.4 and the 23mm F/1.4 but not sure if i want two lenses so close in focal length, purely for landscape and street photography.
23 for landscape and 35 for street?
Fuji RAW files already come into Lightroom sharper than other RAW files due to the way the sensor functions. Lightroom applies its default sharpening assuming a softer image. This default sharpening on top of a sharper RAW from a Fuji camera causes “worm” artefacts.
Capture one does not apply such sharpening by default which many will assume that Lightroom is rubbish. Worming in Capture is quite easy.
So you need to make sure that you set the detail slider to 0, radius to 0.5 and then sharpening slide between 75-110.
X-T3 battery is rather short lived when using the camera for a few hours, looking at getting 2-3 more that i can keep on charge.
I see the Fuji battery is £50 but the Duracell one is £20, anyone use the Duracell one and can verify if it's worth it over the official Fuji one?
This the one?The Duracell batteries are rubbish in my experience. I bought a set of two Baxxtar batteries with a charger and they've been as good as the OEM batteries from new for me.
Congrats, you won't be disappointed.Had a play with an X-T4 in my local London Camera Exchange.
Very impressed with it, though a Canon EOS R almost had me swayed, that thing is super comfortable to hold. The size of the lenses was the draw back for me though.
So took the plunge and ordered the X-T4 with the 16-80mm lens![]()
Congrats, you won't be disappointed.![]()
I always thought when spending ~£2k on a camera it would be a full frame, so I hope I don't regret it.
From what i have been reading, the XF35 F2 is the one to go for, it's worth the extra for the weather resistance and the metal body.ThanksI always thought when spending ~£2k on a camera it would be a full frame, so I hope I don't regret it.
Any opinions on the XC35 F2 as a light weight walk about lens? From what I've read, optically it's the same as the more expensive XF variant, only without weather sealing and a plastic body.
Also tempted to pick up one of these for playing about with over xmas. It generally reviews well as a decent budget option for macro
7artisans 60mm F2.8 APS-C Macro Fixed Lens for Fujifilm: Amazon.co.uk: Camera & Photo
