 - 16 Nov 2009
 - Norfolk
The quest 2 does a way better job than the Rift S on any type of sim Im still wanting  a G2 tho big time for this and iRacing
			The advantage with the G2 is not only with the resolution that works wonders on fine detail of objects like the cockpit displays, but also it's wonder sauce motion vector reprojection. It's night and day better than the Index in visually smooth gameplay in sim titles with very little visual distortion on the image compared to the standard steamVR projection. With Flightsim in mind i'll cite Trucksim which suffers from poor cpu usage that gets amplified in VR, the G2 and it's vector smoothing is a revelation in that game, gone are the stutters around towns and cites.
I've got a HTC Vive and want to try this but bit of a n00b question, basically the Vive uses/needs SteamVR so is it a case of just launch SteamVR before MSFS and it 'just works' or is there more to it than that? I don't need any of the Windows/MS VR stuff right?
Although my GTX1070 is just gonna cry so not sure it's worth it really![]()
I find it varies from game to game, but given sufficient overhead yes it works very well for the most part... tends to work better the higher the resolution is, which makes sense because it has more data to work from of course when plotting the motion vectors of given pixels.
In this game however I'm not sure...
launch the VR software then load flight sim then acitvate VR mode
Sim looks amazing.
Must admit, has given me a goal to upgrade the PC this year - loving the idea of just sight seeing and stunt piloting!![]()
Ill try that thanks for the tip. Im not sure what FPS im getting but even flying into Heathrow its 98% smooth and looks great...Also runing this on a deadicated SSD drive that may help alsoTry glass cockpit refresh rate on high too, it can actually help smoothness in VR.
Bet it’s looking pretty good with those settings though - what FPS are you getting?
Is anyone playing this using a keyboard and mouse? I've downloaded it for my dad to mess around with over Christmas as he used to fly, so don't want to buy a yoke just for a couple of hours, but the keyboard controls seem super sensitive with no nuance at all. Any ideas?
