Reduce Coil Whine Today!
6 Feb 2019
I'm confused
Is the point of this to get your ears so used to bad coil whine that you don't mind the mild coil whine?
I'm lucky though my 3090 has no coil whine and it's the first gpu I've owned in 10 years without coil whine
20 Nov 2020
I'm confused
You're whining louder than the coils, that's why you can't hear it.
24 Aug 2013
Lincolnshire
To be honest you can get rid of it with minor tweaks. You’d be suprised at the amount of noise that gets sent through a gpu backplate and out the back of the I/O ports.
Undervolt can help a lot as well.
Caporegime
OP
12 Jul 2007
United Kingdom
Its not 1st April yet or has someone had too much Xmas vino ?
:D
Not the best start tbf. :p
The purpose of the thread was to help anyone with a GPU with coil whine reduce it, by running the mentioned tests repeatedly.
I have a RX 580 that had bad coil whine, so left it running Sky Diver graphics scene 1 on a loop overnight. It’s now completely silent.
Caporegime
18 Oct 2002
Ireland
Why can't something be done in manufacturing to mitigate or stop this entirely? When this first started to occur on cards a good few years back some manufacturers were encasing the components in a glue type substance and others in a type of plastic to stop the noise, now it just seems they don't bother and it's a crap shoot if you get a card that does it or not.
Used to be you could also rma due to this, but now it's such a common issue the card would have to be smashing glass with it's pitch to get it replaced.
31 Dec 2007
The TARDIS, Wakefield, UK
:D
Vibrated the offending component into submission.
Just get your glue gun out. :)
18 Oct 2002
Eltham
I would happily pay more for a card with a promise of lower or no coil whine, you'd think manufacturer's would use this as a selling point for some of their more expensive versions.
