IPC of rocket lake is defintiely down on Zen 3.
AMD have scope to reduce pricing when rocket drops - and also they will have much better availability by then too.
or they can release better binned chips such as XT range (but makes the naming of CPU similar to the last gen GPU is not a good idea).
Or they can release a whole raft of cheaper SKUs like the 3700x and 3600 equivalent to undermine intel.
Intel is playing ctach up, AMD is coming from a position of strength so got loads of things they can do. But I feel AMD is really focusing on GPU production atm trying to get GPUs out to Sony and MS as well as AIBs and coming up a way to deal with DLSS;
not to mention all the enterprise sectors they are focusing as well as OEM and Laptop space. i don't know if they are going to be biting off too much to chew by spreading their resources too thin. there is only 1 Lisa Su...
if it was that easy everyone would be doing it. never the less you are right, it is true if its something you have the talent for, they don't always get it right. RE: Bulldozer or Pentium 4, its very easy to make mistakes in something that is extraordinarily complicated.
