Good point, I'd prefer an IPS but I might settle for a VA.
I'm in no rush, though.
IPS all the way I cant stand the angles on a VA, IPS is sharper and more colourful. VA reminds me of how dull a TN looks despite the black levels.
I'll bear that in mind, I've only ever experienced TN panels so I'm in for a real treat when I eventually graduate to a 32" IPS.![]()
My impression is that most of the problems were with early firmware. Mine's fine and great value at £325.I keep thinking about taking a punt on this, quite a number of users seem to have issues, though.
Still, very tempted...
Thanks, do you know if it works with G-Sync?
Does it operate at 144hz or is there a drop to 120?
It works with GSync at 144Hz.
Thanks for that, might give it a shot just to see if any difference.I've calibrated mine so thought I'd share my settings (YMMV). I used DisplayCal and the Spyder5 to get it to a colour temp of 6500K, gamma 2.2 and 120cd/m3 brightness. Settings (anything not mentioned was left at default):
Brightness: 23
R: 95
G: 94
B: 99
The icm profile is here: https://gofile.io/d/zYakZU
Overall I'm happy with it since I got it for £325 but I'll be returning mine since, apart from the buttery smooth 144Hz which honestly is eye opening, it's a downgrade from my 34UC98 in every other way. So back to 75Hz land for now while I save up for a 'proper' one.
Mainly just better screen uniformity. This has worse contrast and (it could just be my sample) there a colour temperature shift when the screen is viewed from the left compared to head-on (it appears much warmer). The left and right edges also disappear into the panel when viewing from the centre, I never noticed this as much on the LG due to the curve. Gaming is only about 10% what I do so I don't really need it right now. Although looking around, it seems the next cheapest 21:9 IPS 144Hz screen is double the price of this so it's likely I'll take a chance on another unit when have time to game properly again.Thanks for that, might give it a shot just to see if any difference.
Out of interest what do you find better with the lg?
Considering one of these as an alternative to the Gigabyte 34" ultrawide which has me perpertually on pre-order. What's the general opinion on the comparison of these monitors?
Next cheapest would be the Acer Nitro XV340CK . It's perhaps 100-150 quid more expensive than the Iiyama
I was looking at that one the other day and nearly pulled the trigger due to the reduced price. Normally, it's a lot more expensive than the Iiyama.
