5900X, if budget doesnt matter. 5800X is a good buy in my opinion. My 5800X i paid scalp price so paid the same as a 5900X.I'm still using a 3600 but been looking to later upgrade to the 5800X or 5900X. This would probably be my last upgrade for a number of years so not sure which would be best.
Great CPU so the 5900X with it's additional cores isnt going to be worse
This is a good test of performance. Drop here and look out the window, what FPS do you get?
With the 461.09 and 460.89 I had around 60-70fps. 445.87 I hit my fps cap of 90fps+ as seen in screenshot below. This is with Geforce experience filters on, 3440 x 1440
Quite a beefy loss of performance. I'm sure Nvidia are doing similar to Apple and building something into the drivers that cripples 1 generation older tech similar to newer iOS versions on older devices!
As mentioned above i very highly recommend the LG27GN950 if you can get hold of one , you will not be disappointed
