The Radeon RX 6900/6950 XT Owners Thread.
It's here. Finally :D
Congratulations, she sure is pretty.
Thanks, If only installation came easy :D
5700xt was in secondary pcie slot. Now with AIO, I thought I'll move 6900xt to primary slot.
Started PC, went into windows, I thought, I need to reboot quickly, maybe I forgot to set pcie modes to gen 4. Check BIOS, all seems ok. Then in the maze of x570 BIOS, I notice the resizable BAR is available. And in order enable it I have to disable CSM. So I do that, enable snickers bar, save, restart. Goes straight to BIOS again. Non of my SSDs are available to select as boot devices, and can't even select different boot order. Enable CSM back, save, restart, blank screen. Reset the BIOS, load the profile which worked for me before, select my boot drive as appropriate. Save, restart, boots straight into BIOS :D
Thought that would be great time to update BIOS to agesa 1.2.0.
And now I seem to be able to boot into windows. But I guess I'm not touching rebar for some time :D :D
You need to install Windows in UEFI mode and to do that you neee CSM set to disabled, secure boot on, then you can enable Bar.
my asus rx 6900xt is out for shipping, when the ek block and backplate also arrive direct from ek i'll post pics, then time to benchmark :)
Try disabling compatibility support module (CSM) under the Boot menu in the BIOS.
Thank you, will give that a go. If not ill unplug all my USB devices other than keyboard and see if i messed something up when plugging them back in after installing the card. Other option is just to get a Zen3 and X570 board lol.
Welcome and on TROH.:)
The Roll of Honour.
Date 26/01/2021, Make AMD Reference, muziqaz, Link
Date 26/01/2021, Make AMD Reference, Conanius, Link
Date 24/01/2021, Make PowerColor Red Devil, eeii, Link
Date 23/01/2021, Make PowerColor Red Devil LE, Too Tall, Link
Date 15/01/2021, Make AMD Reference, Overlag, Link
Date 14/01/2021, Make XFX Merc 319, Seanoog, Link
Date 14/01/2021, Make PowerColor Red Devil, Heofz, Link
Date 13/01/2021, Make XFX Merc 319, ch99mr, Link
Date 10/01/2021, Make AMD Reference, Breezer, Link
Date 10/01/2021, Make XFX Merc 319, ronski, Link
Date 07/01/2021, Make AMD Reference, Biffa, Link
Date 06/01/2021, Make PowerColor Red Devil, heartburnron, Link
Date 04/01/2021, Make Sapphire Nitro+, Mister_tangerine, Link
Date 01/01/2021, Make Sapphire Nitro+, Jumper118, Link
Date 01/01/2021, Make AMD Reference, Jumper118, Link
Date 31/12/2020, Make AMD Reference, NathG79, Link
Date 30/12/2020, Make PowerColor Red Devil, Nugsy88, Link
Date 27/12/2020, Make AMD Reference, LtMatt, Link
Date 26/12/2020, Make AMD Reference, Abhishek Shukla, Link
Date 24/12/2020, Make AMD Reference, ch99mr, Link
Date 24/12/2020, Make Sapphire Nitro+, hornytoe, Link
Date 23/12/2020, Make AMD Reference, Diplodocus, Link
Date 23/12/2020, Make AMD Reference, DeathStorm, Link
Date 23/12/2020, Make PowerColor Red Devil, Jonnym28, Link
Date 17/12/2020, Make AMD Reference, DustyMiller, Link
Date 16/12/2020, Make AMD Reference, Curlyriff, Link
Date 16/12/2020, Make AMD Reference, Chewie, Link
Date 16/12/2020, Make AMD Reference, Too Tall, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Radeon RX 6900 XT.
Was on Pubg last night.
Running a steady 2300/2005 @1075mv.
Maxed out on Ultra. 1440p.
GPU Usage was jumping around a bit depending on what map I was on.
Dipping down into mid 30% but also pushing up to 99%.
Ran Furmark afterwards and GPU holding at 99%.
Is this normal?.
Is this normal?.
Yeah it's normal. The 6900 XT requires a 5000 series CPU for optimal performance.
If you could switch to a 5900X, or even a 5800X and also enable Smart Access Memory, you'd see your GPU utilization remain at 99% solid more frequently.
A monster of a GPU needs a CPU with high IPC to drive it.
Yeah, that makes sense, I have enabled SAM in the Motherboard bios and it shows as large memory access in Device manager, but like you say, the 3900X is not letting it fully stretch its legs.
Maybe the next upgrade when there not vaporware/Scalped to ****.
5800X is available right now at RRP, but can't see stock for the higher models atm.
