I pasted some Thermal Grizzly on the bottom of the Spire heatsink and that's done the job. No more thermal throttling. It's now only throttling due to the power limit and running a sustained memory overclock of +1300 and 2000 MHz GPU core clock.
I thought the right to repair meant this warranty rubbish was going away?
You can still remove stickers so its hard to tell you opened it up.
Hey, thanks for the link to this thread. Could you post the raw pic without the thermal mode please so I can see what you did?
I'm looking to get some thermal grizzly 3mm pads for the mem and backplate and then some 2.5 mm to replace the factory ones by core.
I had seen redpanda from redpanda mining have to do this. Didn't fancy ruining my warranty though.
The latest HWinfo now includes Vram temps.. It looks like there is no way to monitor the temperature of the memory chips right now
This is really interesting as I have been doing some mining on my 3090 when not gaming and getting some low results with not being able to push the memory past +700. Now having used HWINFO I can see the RAM is hitting 100 degrees so I think the card is then thermal throttling as described.
 about GDDR6X and thermal throttling. Maybe they should start doing waterblocks that cover both sides of the card!
That is truly savage and highly commendable![]()
Whilst I admire the ingenuity it seems a lot of money to pay for a GPU only to have to ghetto rig some extra cooling.
Haha, yes it was a pragmatic / hacky workaround to a problem. Being a software developer I'm used to doing those! I'm sure there are more elegant solutions requiring more time and effort, but so long as it works then I'm happy.
