I'm looking to watch movies on this TV with headphones. What's the best way to do this, would I need to use some sort of amp for best sound quality?
Bluetooth headphones are a bit hit and miss due to sync issues. Anyone using wired cans?
I run it via optical output to a headphone amp (Topping Dx3 pro) optical in, and then headphones connected to it. You don't have to buy the most expensive gear going though but optical output is the cleanest and digital connection going. Still what stooeh suggested is even cheaper and better.
Should work fine wired, personally got the headphone output going to line in on back of PC (with a cheap ground loop isolator to avoid the buzz) then I just listen via PC headphones.
I had no idea such an product existed that really is quite nifty device to have, does it completely eliminate all the back ground hiss ?
