basically you can’t run 120hz, 4k in full 4:2:2, 10bit colour on hdmi 2, you need 2.1. You could drop to 60hz and gain back 10bit. so, really, to get the best out of this cx oled you need a 3080 / 3090 series card.
I can’t understand someone paying £1400 for this display without first owning a much more important 3080/3090 GPU that cost from £650.
Lets not have another argument, You can run 4k @120hz 8bit 4.2.0 no one said 10bit, also you don't need 3080/90 to run this OLED a 1080TI/2080TI can run this TV without problem so no need to upgrade just because it has a HDMI 2.1 it also have 4X HDMI 2.0
Because an OLED TV is more superior image quality compare to QLED/LCD/LED, and you don't need a 3080/90 card. plus stop been a troll on this thread if you haven't got anything positive to talk about, also don't tell people how to spend their money it's not up to you.
What are you guys using to play movies with DTS audio? I just get "this video does not support audio" when trying.
Plex app on the LG does a good job, just make sure in your plex server (pc) and in the plex settings (tv app) you uncheck DTS audio, this way it converts any video file to an audio format that works (plays back) so you can hear it.
Using the inbuilt tv app is almost pointless since you may come across a video with DTS audio, something the LG does not support since DTS is apparently on its way out.
I see, I did install Plex on my PC and opened it on the TV but couldn't really see how to view my own movie files on my TV! Will have another go at it, thanks!
So you buy an OLED to run it without the full colour - good luck getting that true HDR then. May aswell buy one and run it at 1440p....oh wait - many did
no one is arguing but you
Tnx god i didnt go for the radeon series as the infinity cache and 4k dont mix too well.
For the last time, I play 4K games with HDR on, I still get all the superior benefits of oled, also I rather have oled with a old GPU then have a old LCD with the best 30xx card.
For the very first time to use my ignore list I add your name
Ah another troll added to my list
childish
I got that desk i think its called Ikea Fredde and i see you had to remove the top shelf. I was concidering to do the exact same setup but i got a little window behind at the right.
I was wondering how confortable is it because i can see the eye level would be in the middle vs how high that tv top part is. Well done on the awesome setup though.
