- 14 Oct 2007
- newcastle
What settings are you finding your PPT,TDC and EDC are needing?@Towel start at +0 boost, auto scalar, mobo limits and adjust curve first. See how negative you can go all core (usually -30) and then start to adjust based on how each core performs (can also check their peformance score in event viewer, ID 55).
Best cores won't need as much negative curve, but your worst can go quite far (majority of mine are -50). Once you find good curve vs performance you can start to add boost and then after that test out manual PPT, TDC and EDC, which should help reduce temps a bit. Leave scalar on auto.
