Sure. Which 3080 btw? And don’t forget the 1440p bench! Thanks for the input.217FPS today was with stock CPU (PBO auto) and stock GPU
I'll do a stock re-run with HWiNFO64 montoring
3080 Nvidia Founders. 1080p above with temps. 1440p bench here -Sure. Which 3080 btw? And don’t forget the 1440p bench! Thanks for the input.
Thank you so much for this.3080 Nvidia Founders. 1080p above with temps. 1440p bench here -
https://forums.overclockers.co.uk/posts/34522558/
Will also get one of HWiNFO64 monitoring temps
No probs
1440p with monitoring...
No problemThank you so much for this.
My avg fps was 136 in the ss I posted. So the 2-4 extra fps you have must be from the better ram and cpu. I thought something was wrong with my card since I was getting only 17300 graphics score in timespy. This shows that my card is perfectly fine as it should. And also max temp of 65degrees at stock fan curve? Your ambient must be super low. I get max 73 at default curve and max 65 with the msi afterburner default curve.
Also yes, I’m on the latest driver, did nvidia nerf the clocks or something. Did you try the 461 driver?
Great case! I own the Lian Li mesh 2 with three front intake, two bottom intake, two top exhaust and one rear exhaust. All Arctic p12 fans running at default speeds from bios.No problem
Fan curve im using is this
Ambient / idle temps is around 20c.
Case is Phanteks P500A. 2 x 140mm Noctua fans in from on 40% 1 x 140mm exhaust on 40%
I tried the 461 driver and it seemed to cause stuttering in Warzone
Thanks a ton once againI had vanguard for valorant running in the bg, it’s installed in the kernel so couldn’t remove it. I’m on the balanced power plan in control panel. I hope this didn’t affect my scores. And if you don’t mind me asking, what is your graphics score in timespy? Currently. Here is mine for reference. All stock. Hope this isn’t against the rules since it’s a unigine thread.
300points more than mine at stock? Damn lol it really must be my driver or my cpu is holding the gpu back.That must be a lot of fan noise! I'm using 3x Noctua NF-A14 PWM (chromax black)
Score look spot on. Here's my stock run - https://www.3dmark.com/3dm/57863461
It's possible to get upto about 19k but Timespy isnt a great test of (modern) GPUs really.
Something like the Direct X Ray tracing feature test is, or just load up Quake II RTX with uses full path tracing and loop the demo scene. Average CPU clock will be a lot less than Timespy as its running flat out (and about 2% CPU usage)
It does fluctuate with every run. 300 points will be something like 1 fps playing at game 1440p, if that300points more than mine at stock? Damn lol it really must be my driver or my cpu is holding the gpu back.
Noted. What power plan in windows do you recommend? Thank you for the all help. Hope I’ve not taken too much of your time. Back to gaming now!It does fluctuate with every run. 300 points will be something like 1 fps playing at game 1440p, if that![]()
My Ryzen 3600 had some built in power plan like 'Ryzen balanced'Noted. What power plan in windows do you recommend? Thank you for the all help. Hope I’ve not taken too much of your time. Back to gaming now!
https://hosting.photobucket.com/ima...png?width=450&height=278&fit=bounds&crop=fillfile:///C:/Users/Pictures/Screenshots/Screenshot%20(2).png
yes this gen ryzen doesn’t need any power plan and it actually recommends the default balanced one.My Ryzen 3600 had some built in power plan like 'Ryzen balanced'
When I installed the 5800X though, this disappeared and now use 'High performance' I read somewhere Zen 3 doesnt use the old Ryzen power plans.
Not at all. Working at home allows a breaks from work stuff. Walks, Warzone and forums fill this time nicelyIts not like there's much open outside anyway!
Isnt that throttling causing the 10fps minimum?
i dont know how to check.Isnt that throttling causing the 10fps minimum?
Sorry, i'll re-phrase - that's throttling because of the 10fps minimum.i dont know how to check.
