There seems to be some misunderstanding in this thread about what CTR does. Unlike PBO which just increases power (and therefore heat which could throttle performance depending upon your cooling), clock tuner allows you to get more performance per volt by tuning the performance of each core.
So basically if you have a single CCX chip then it's pointless using per core curve optimiser?.The current public release of CTR has no per core control at all. It has per CCX control only, and some profile switching which is the 'magic' you don't get otherwise.
It's worth keeping in mind that Desktop Zen 3 doesn't even have separate voltages planes for each core. When multiple cores within a CCX request different voltages, the highest VID request wins and the rail is powered with that voltages and all cores get it regardless if they are in their C0 state.
Yip that’s normal.I just loaded this and hit diagnostics with CB20 disabled - its running tests at 4375mhz on my 5600x - is this ok? normal? Am I supposed to change something ? no idea what im doing and guru 3D guide made no sense tbh!![]()
Yip that’s normal.
Playing with it again this morning. It’s passed 4875mhz @ 1.35v. 4900mhz will need a another voltage bump, but I’m not particularly happy doing that.
CB23 results incoming.
*edit*
Reeeeeeeboot
Enable the Autoload Profile with OS toggle. Then in Profile Management click Fill Profile > Apply Profile > Save Profilegreat!
ok so it’s tuning at the moment, how do I save it and make it work all the time? P2 save or something?
so far it’s at 4825mhz 1.3v
https://www.igorslab.de/en/clock-tu...en-5000-hybrid-oc-phoenix-mode-and-much-more/
This guide is much clearer than the one on Guru 3d. Re: DarkBahamut - It clearly states that in P0 and P2 profile CTR is able to put cores into a sleep state to prioritise the 1 or 2 best performing cores. The program switches between purely single threaded P0, heavily multi-threaded P1 and partially multi-threaded (gaming) P2 according to the CCX load. I am not sure if they or you are right about the individual cores but the way it adjusts load to optimise where the power goes seems intelligent
you can see it in the log - no need to rerun - its all thereCTRLOGS subfolder
cheers
C
I'm a bit lost.DIAGNOSTIC RESULTS
AMD Ryzen 7 5800X 8-Core Processor
Max temperature: 69.4°
Energy efficient: 3.88
Your CPU is SILVER SAMPLE
Recomended values for overclocking (P1 profile):
Reference voltage: 1250 mV
Reference frequency: 4550 MHz
Recomended values for overclocking (P2 profile):
Reference voltage: 1325 mV
Reference frequency: 4625 MHz
Recomended values for undervolting:
Reference voltage: 1125 mV
Reference frequency: 4300 MHz
Just I'm not seeing in CPU-Z my CPU run at the P1 profile speed of 4250Mhz. Am I missing something?
