What temps does your strix hit on the memory?
88c
And when mining ETH for ~1hr?
I've had a fan pointing at the back of my 3090 since day 1
The gpu sits at about 50C after gaming.
is that the memory temp?
No that's the GPU temp @2070hz
I have never found a way to monitor the memory.
If you tell me the software I will try it now.
use latest version of HW info, its called Memory Junction Tempreture
I get a prformance limit thermal yes when using realbench but memory junction temp only reaches 75c and gpu only reaches 52c but I don’t get it when I run timespy. Water cooled strix 3090. Not sure what’s happening.
 Since changing the pads the temps are better but still a touch hotter than i would like ... desperate for the watercooled backplate that is being released for the Strix... that should defiantly sort out the memory temps
Where did you find out about the thermal pads being wrong? I had my ek strix backplates in one of the first shipments so I must have the wrong thermal pads on too.Yeah I've noticed the same on warzone, watercooled 3090 Strix with gpu sitting at 51 deg and memory sitting at 72 deg but then check HWinfo and it says a thermal limit was triggered apparently
Leave it mining all night and memory will sit between 96 deg and 104 deg depending on how much the radiator fans are ramped up yet no thermal trigger .... I will also add due to EK backplate instructions being wrong i originally had 1.5mm thermal pads on the rear memory but turns out these weren't even touching and needed to be bigger ( 2mm+ ) as when i first tried mining memory would go straight to 110deg and throttleSince changing the pads the temps are better but still a touch hotter than i would like ... desperate for the watercooled backplate that is being released for the Strix... that should defiantly sort out the memory temps
Would highly recommend you pull your apart and replace with 2mm pads .
	I heard about the thermal pads potentially being wrong on the EKWB facebook group but when i fitted mine originally i must admit i didn't bother checking contact and assumed the instructions i used at the time were correct as they stated 1.5mm pads but now just been changed to 2.0mm ( https://www.ekwb.com/shop/EK-IM/EK-IM-3831109832479.pdf ) i assumed all was good as until recently we couldn't see memory temps on the strix but even then it wasn't till i started mining last week that i noticed an issue as the memory would go straight to 110deg even with stock memory clock so i pretty much knew the pads weren't touching the backplate ... pulled it apart last weekend and as expected not even touching 1 memory chip but was cooling an important screw
double stacked with an extra 1.0mm set of pads ( temporarily as was waiting for Minus 8 pads which have just turned up today ) and they do make contact and temperature has dropped as expectedWould highly recommend you pull your apart and replace with 2mm pads .
Thanks I appreciate the information. I well can’t be bothered to take loop to pieces again. Ek should be sending out replacement thermal pads if that’s the case. Might contact them to see what they say.I heard about the thermal pads potentially being wrong on the EKWB facebook group but when i fitted mine originally i must admit i didn't bother checking contact and assumed the instructions i used at the time were correct as they stated 1.5mm pads but now just been changed to 2.0mm ( https://www.ekwb.com/shop/EK-IM/EK-IM-3831109832479.pdf ) i assumed all was good as until recently we couldn't see memory temps on the strix but even then it wasn't till i started mining last week that i noticed an issue as the memory would go straight to 110deg even with stock memory clock so i pretty much knew the pads weren't touching the backplate ... pulled it apart last weekend and as expected not even touching 1 memory chip but was cooling an important screw
I haven't found any easy way. Maybe there is a way to generate error log files for VRAM, but if there is I have no idea how to do it.
The only reliable way we have is benchmarks. Set a base line score in 3d mark timespy with stock clocks - and then you can start increasing memory clocks speed, you'll know when ECC kicks in because the benchmark score will drop a lot. In 3d mark timespy I go from 21000 score at +200mhz on the memory to 15000 score if I go over that due to ECC.
Because of how ECC works, I believe it's beneficial for everyone to run timespy at least once with the card stock when they first get the card so I can set a baseline. Then in future if you suspect something is wrong with the card or you are just curious, you can run timespy again and compare against when you first got the card and if the score has dropped significantly then you know something is wrong. It remains to be seen if prolonged high tempreture on the GDD6X memory will cause the memory performance to degrade over time, but if it does degrade you will see ECC kick in and drop your performance so its a dead give away.
