My solution was the
EK WATER BLOCKS EK-RAM MONARCH X4 CLEAN - NICKEL
which i managed to pick up in a sale for £20.
That and the best w/mK pads between the chips and the backplate keeps everything cool.
Isn't that thing a bit long for 3900FE? there are these X shaped ribs that is in the middle of the back plate, the rib is slightly raised, so unless your blocks are shorter it won't be able to make direct contact with the backplate unless you put some seriously thick layers of thermal pads in between.
Thanks I appreciate the information. I well can’t be bothered to take loop to pieces again. Ek should be sending out replacement thermal pads if that’s the case. Might contact them to see what they say.
Heatsink best fit is at 100x100mm. It won’t thermal throttle now however still runs at around 100 degrees
Still gets to 100c? Lol told you it wouldnt be better than improving case airflow. Did you stick it on backplate or?
	Thanks Jay yeah I’m still getting thermal throttle yes no matter what now so I guess I will have to drain down and change out the pads. Thanks for sharing the vid.Yeah it is a pita having to drain the loop to get at the backplate but i would highly recommend you give it another go as if you used the 1.5mm pads i bet they are not even touching the back plate ... Debauer had exactly the same issue in this video at 3:50If you send EK a ticket they will send you a new set of pads and screws for free![]()
I've posted image of this already, here is it again, I am running an open case TT Core P5, so airflow isn't really a problem.
It is worth noting I am getting 125MH mining with this setup, which is really good given without it it would throttle at 80Mh
wanted to check if my 3090 suffers from the RAM overheating/throttling issue.
I've loaded HWInfo and can see the RAM gets to 82C when playing Baldurs Gate 3 ... I can't see the GPU core speed drop so think I'm ok but not sure if I'm measuring right.
Assume I also need to check GPU fan speeds aren't getting to 100% Is there anything else I can use to verify?
He already has HWInfo installed, it has a column called 'max' that will tell you what its reached. It was in response to rest of his message:
I gathered that but I was replying to Minstadave.![]()
I thought you were helping bignev72.
I used a large 1mm thermal pad, it is held on by mavityI was going to do this for my 3090fe also, ordered a fan and a heatsink.. but after I put in the GPU in my case I realised that my NOCTUA NH-D15 is so big that there is hardly any space between the back of the card and the heatsink.
Ordered a new case and an AIO this morning, once I transfer the PC into that I will be able to do what you have done.
Did you use a any thermal pads/paste in between the heatsink and the card? I also ordered a piece of thermal pad, thinking if I should add that into the mix also.
 But the bad news is that my 3090 is still throttling according to HWiNFO64
