RTX 3090 Watercooled Temp
I have mine similar to Jay, but I have mine on softtubibg, and I have the connections reversed on each tube, so I can plug them together when I disconnect the external rads
Mines the same haha, one male and one female so i can adapt them but then realised i cant cos im using hardline on the pc side...
I suppose i could still if i have the QD's on 2 90' angle fittings so it does a u-turn.
You can plumb them straight into a radiator buy you'll need a male/male extender to convert the thread.
https://www.overclockers.co.uk/ek-w...e-male-extender-satin-titanium-wc-a0s-ek.html
Am I being an idiot or do the ends look different on this image?
Ah yeah or you could buy this one and plumb that straight into the rad. It's just a different thread for different mount.
Basically the threaded part would go into any female threaded component like radiator, block, res etc.
The other end will require a male QD to connect it to the tubing side.
Yeah so plug two of those directly into the rad
and maybe put an angled fitting in there somewhere as well.
I think I am getting it a bit more now.
Just confused by ocuk stocking those particular ones.
If you google around, you can get 3 types of Quick Disconnects,
Ones that you have linked that are screwed into block, radiators, and angled fittings..
Ones that you need to get fittings for your tubing so you can mount them to just the tubing..
And finally Bulkhead/Passthrough Quick Disconnects, that are for use when you want to attach them to say a hole in your case, like the back where you secure it with a collar on the fitting. These will usually require a fitting for your tubing to attach to them too.
The number of choice is bewildering initially, but gives you options for your own setup.
Thanks to the earlier 2 posters who replied to my question re separate loops. I'm just wondering how much a waterblock cools the memory? Too anyone that has one, did it make a big difference or will an active backplate cooler be necessary do you think?
From what i've seen so far, not that much if im honest. A few degrees it seems at most, might see better results using thermal paste instead of pads.
Thermal paste requires direct contact, it will not work if there are even a 0.5mm gap between the contacts, thats what thermal pads are designed for. Thermal pads and paste is usually not interchangeable without significant impact on cooling performance.
True, the backplate and block would need near perfect contact and the way its mounted unless screwed down wont make any good contact.
This is what i was abit surprised with the aquacomputer active cooled backplate, it didn't perform particularly well...
Could always just point a fan directly over the backplate with a row of heatsinks stuck on the back :p
Yup behold! my super getto setup right now ;)
I pretty much did the same think but uses a 980ti FE heatsink on the hottest spot, that alone drop the memory temps some 8c (92c to 84) adding a fan dropped this to 80c over time.
I have a much bigger heatsink ready to go on for my new build
Checkout my thread here:
https://forums.overclockers.co.uk/t...ce-with-the-ekwb-3080-fe-waterblock.18919890/
Apparently cooling the Memory through PCB is sufficient if you can get the GPU temp low enough.
Thanks guys. I'll just stick with the traditional waterblock. I've got an Suprim x so not much choice waterblock wisr
