I talked about it a few pages back, but I took a punt on a cheap Pro-style controller from Amazon for £17 before Xmas and have been impressed with it. I wanted a 'proper' controller for the Switch I was buying our son - figured he might end up preferring the JoyCons (he does) but that I would prefer the 'real' controller (I do)Pretty sure I will get the new 3D World game, but with it being coop I'd like to get another controller. Is the Switch Pro controller the one to go for? Or is there a decent cheaper alternative?
Decided to go with Mario 3D world. Enjoying it so far but I still can not get the hang of targeting jumps to get coins/break walls/stomp enemies. Any tips on this?
Nintendo gods, please give us Mario Golf tonight.
Thank you.
As far as I have figured out, the medium sized and smallest sized characters have to use ground pound by pressing A (or B) followed by the left shoulder button ZL to kill enemies. Make sure that your shadow is over the enemy in order for the ground pound to get a direct hit. To break up blocks that look like brickwork, or blocks that are embedded in walls behind you, I don't think it is possible to break them with your small or medium character. You have to get one of the upgrades e.g. cat or squirrel and then you can use your tail to attack them.
Edit: If you are on World 5, there is a level with Bob-ombs and you can make them follow you. Lead them towards the walls that have breakable parts and they'll blow it up for you.
About cat/squirrel upgrades, this is something I haven't figured out yet, but sometimes, if you press LEFT on the d-pad, a bell appears and then you can turn into the cat/squirrel. Sometimes LEFT doesn't work, so I think you only have a limited stock. Maybe once per session. If someone knows how that works, then that would be really helpful
Would have liked to have seen something of MP4 or something more about Animal Crossing that we hadn't already been told would be coming.
Thanks for the tips. Im slowly getting accustomed to jumping and stomping enemies. Im still world 2 trying to find all the green stars and joysticks even though l dont know what the joysticks are for lol
Thank you.
