 - 3 Mar 2015
 - Wokingham
So to conclude, you think that mining overall can not be considered wasteful, no matter how many GPU's it is using on full blast, as long as it is also being used to heat the room it is in.
Irrefutable logic.![]()
Yes, this is correct. If you wpuld have heated that room directly or indirectly by fossil fuels, then you may as well heat it by mining instead There is no waste there. The waste comes when you need to get rid of excess heat, such as when you mine in summertime. Then that isn't good for the environment.
