My gpu score is pretty similar 10515 but cpu does seem to be quite a bit lower at 9039, wonder what could be causing that it is hitting 97c mind so could be throttling, I’m tempted to repaste the heat sinks but may wait a while before doing that
What exactly did you do in bios again as I notice in your screen shots voltage Id on right is 0.8. Ish mines 1.2?
Just checked mine didn’t have speed shift - epp ticked have done now but now have also mine hadspeedstep ticked so have undone that it’s dropped to .8 now but fluctuates back 1.2
scratch that! That was in performance mode
Got my laptop ordered today..... I caved and bought 32gb ram kit and 2tb nvme![]()
Ive currently got a MSI and like the build quality. Is that the main benefit in spending a couple of hundred more on this, than a ASUS ROG equivalent?
I mean the MSI seems to be left behind in terms of CPU by having a Intel, so whats the price difference cover?
Im sat here waiting to spend, but I feel like im in a minefield and there is only one square I can stand in without blowing myself up![]()
is that done in bios? I havent tried that
I returned a just released ASUS G17 with a 3070 before getting my GE66 as it had buzzing speakers and the front RGB strip was non functional. In terms of build quality the GE66 feels superior in every way, not just because the ASUS had some faulty components, but the GE66 just has a much more solid feel to it and is constructed with better materials. You can see the difference in build quality when you compare the internals as well, the GE66 has obviously had more thought put into it. I've also found in my experience that the GE66 gets better framerates in games when you use the mux switch to bypass the Internal GPU and solely use the 3070. I also haven't found the Intel CPU a hindrance at all when running games.
Finally, not being able to turn off optimus on the ASUS can reduce your fps in many games, and drastically reduce it in esports titles. The fact the MSI has this mux switch makes it worth the price difference alone imo. There's quite a few videos on YouTube about this, here's a good one:
