Hmm sounds like a glitch and you are on the latest firmware I take it?
have you tried to reset the tv to factory settings and then disable that timer and then see if it still has the same issue perhaps. If not worth asking LG support to fix the bug, obviously switching that timer off it shouldn't pop up.
Ill disable mine and see how it goes over the next few days also.
Yeah could be a glitch - yeah autoupdate is on and nothing new to d/l
yeah I might resort to factory reset - problems with tv's now, so many menu's and sub menus its not easy to put everything back hahaha
Will do this over the weekend
How did people rate this for productivity? I'm going to have a 1m deep desk so within the realms of workable for me.... if it's worth it.
I have to say I really like it
I tried a 49" curved screen and that really annoyed me (Ive got a relatively flat curved dell 34" as my personal pc monitor which I really like - but the 49" is too curved for me, and was constantly bugging me
The CX however is brilliant imo, all the benefits of two screen without the bezel between. I have Outlook and Teams open constantly and usually multiple browsers and odd txt and other files open, and so much easier without constantly shuffling them around on a much smaller screen
Admittedly my desk is actually a dining room table so the depth isn't an issue at all, but Im still only 1 1/2 meters away from it (and no issue with docks either, which can be fiddly with resolution changes when alternating between work and home)
