Have this odd issue on the latest driver where from a cold start the active signal resolution changes to 4096x2160, whereas the desktop resolution is and should be 3840x2160.
If I go into NCP I have to switch Perform Scaling On to GPU, then Display, to get it to switch back to what it should be on both, 3840x2160.
Only started with 461.40. Not sure if it makes a difference or not but it doesn’t seem to happen if I set it to 60Hz, seems to happen every time when set to 120Hz, yet it’s been at 120Hz with all the previous drivers without a hitch.
Could roll back to an earlier driver but it only takes a couple of mouse clicks to fix, albeit bloody irritating.
