Fairly sure you're joking, but the reason B.O.DM.AS gives equal precedence to Div/Multi, or Add/Subtract is simples.Following BODMAS the answer should be -25 as BODMAS has to be done in that order. However many folks on here are doing BODMSA instead to end up with -15 although there is the claim that you don't have to stick to AS order you just have to go left to right with AS which would mean using either AS or SA
Anyway,
5-5x5+5 = ?
5-(5x5)+5 = MULTIPLY FIRST - BODMAS
5-(25+5) = ADDITION SECOND - BODMAS
5-30 = SUBTRACTION LAST - BODMAS
or
5-(5x5)+5 = MULTIPLY FIRST - BODMSA
(5-25)+5 = SUBTRACTION SECOND - BODMSA
-20 + 5 = ADDITION LAST - BODMSA
Giving -25 or -15 but there's a few ways of doing it which will give different answers so, in the end, the real answer is the lessons we learnt on our journey to find the answer!![]()
The order you perform addition and subtraction doesn't matter. Similarly with div and multi.
+5 +5 -5
-5 +5 +5
+5 -5 +5
all the same answer (42).
10/2*4
4/2*10
e: correction, the above should read:
0.9999r/2*10*4
5-5x5+5 is basically
+5 (-5x5) +5
+5 -(5x5) +5
-25 +5 +5
+5 +5 -25
