Best thing to do is a fresh install of windows. Pretty much solves issues most of the time. I do it every time I switch from AMD to Nvidia or vice versa. Does not take long and you can do it while multi tasking so time is not wasted.
   ^^^^^^Depends on how many things you have installed I suppose. Gone are the days where I would have loads of things installed. If you have your steam games, videos and pictures etc on a separate nvme already then when you reinstall windows they are there waiting too. So what are we talking about here a couple of hours at most. Windows itself installs in like 10 minutes these days. Never bothered me as I do like a fresh clean copy of windows installed.^^^^^^
I can't remember the last time that I formatted my C drive to reinstall Windows on my main PC - I'm talking several years here. It isn't the time taken to do that but the ages afterwards getting everything set as I like which just completely turns me against such extreme measures, well extreme for me.
I went from an Nvidia GPU to a new AMD one and just used DDU, and after refunding the AMD and then went back to a Nvidia card and still used DDU. From there to a new Nvidia GPU, still using DDU, when I was finally able to buy one.
All well in each circumstance.
Indeed. They have no loyalty to us either so why should we be loyal? I go with whatever takes my fancy at the time@TNA has no loyalty to brands so he flip flop n ****![]()
LolOoh, errr...![]()
that's the CIA/NSA etc swapping operatives. What have you been browsing for>?I about 6 weeks ago bought a 3070 and ever since every now and again, like once every other day (not while gaming and didn't do it with the AMD card) only while browsing with YouTube open the display freezes for 30 seconds and then resumes. No black screen. Do any of you guys get this problem??
Ive tried the latest driver and still get the problem.
I did swap from an AMD card. I didn't DDU or reinstall windows.
For me it is probably more of the thought than the actual doing of it, altho, like I mentioned, it has been years since I did such a thing. With making regular Macrium backups of a working OS I would see no need to either.
Each to their own but I would not feel the need to do a full format, as a matter of routine, when switching GPU brands.
strange problem
trying to update drivers to the latest ones. get half way and the pc reboots. drivers are not updated
Used it a few times when I have been lazy to do it manually. Works well.Seen some saying to use this on reddit:
https://www.techpowerup.com/download/techpowerup-nvcleanstall/
Anyone here done it and not had issues?
