- 1 Jan 2003
- Derbyshire
it would be cool of flyingfish to post similar video without dram calculator timings to see how much they can improve performance by themselves in such a cpu limited game
i thought those results were without any optimized timings but in the same time i suspected, because the usual difference between 2700x and 5800x is %50. but by my calculations, i was %50 behind him with optimized timings, and i thought if he were to use optimized timings, he would have %60-65 lead. turns out he was also using optimized timings, hence explains the %50 difference
optimized timings in this game can bring another %10-15, so it may be worth it if you can replace your board with a b550 with small price (selling your x470)
Well if your interested I've just updated my motherboard bios to try out resizable bar, which has reset my bios settings. So just for you here are two video's of before and after.
The first is totally stock settings on the cpu and memory and gpu at stock clocks but 117% power.
The second is again stock cpu and gpu clocks, but tweaked memory timings and resizable bar enabled.
Only a few frames in it, so not a massive increase at 1440p, but it felt a lot smoother. Although I've only done this small test so far.
