Always
My peripherals will be up there soon, my PC has already left the building
I will need to buy some sort of USB hub...
Following on from @ChrisBuzz, has anyone got any recommendations for a USB-C TB Hub that works with Apple Silicon and supports GB Ethernet, HDMI and headphone jack I/O that isn't horrifically expensive?
Mate. Do you have your own mailing list? Can I sign up?Always
My peripherals will be up there soon, my PC has already left the building![]()
It's only 4k at 30 Hz which won't look great.My go to is Anker -> https://www.amazon.co.uk/Anker-PowerExpand-Ethernet-Delivery-MacBook-Gray/dp/B08CKXNJZS
No 3.5mm jack though, that's quite uncommon on USB-C hubs.
Yep they look great. Part of me is a little jealous that I'm not in the market for a casual desktop right now because I'd order one of these in a heartbeat.If this does not win multiple design awards I would be very surprised. It is one of the most elegant, modern, industrial designs I have seen in years.
There are a few like the Elgato Pro Dock, OWC TB3 Dock, Anker Docking Station etc that look to offer what we would need but at £250-300 per iMac.....it's no bueno.
Looks ok and with an Apple 3.5mm adapter, it probably makes it one of the cheaper options compared to other docks available.
Is the HDMI output likely to be DisplayLink/software based?
It's a reasonably good looking machine but it's essentially the casing from the iPhone/iPad Pro (without the camera-bump) enlarged with a few extra ports; i'd argue the G3's were more revolutionary in terms of design compared to what we're seeing with the latest iMac.
Can I ask why you need a dock? It has Gig Ethernet and a 3.5mm audio jack built in. All I see that isn't is a USBC/TB3/USB4 etc to HDMI? which come in cables.
Keep an eye on the 2nd hand market. I picked up one of these for about £20...
https://archive.caldigit.com/thunderbolt-3-dock/thunderbolt-station-3-Lite/
Works perfectly with a normal Intel 2020 iMac, but don't know about the M1.
I also have an almost identical unit from StarTech (model TB3DK2DPPDUE) for about £70 which works too. It's basically the same - probably came from the same factory.
I remember seeing the G3 on display in harrods and being stunned by how amazing they looked. I was 12-13 years old![]()
showing your age there bud, the g3 launched in '98![]()
