What's the output of that charger?Doesn't work with my Ideapads USB-C charger.
It will likely charge it but only in sleep/powered off.
I can confirm it charges via USB-C when using a 100w USB-C PD charger with the laptop powered on.
I get a "slow charger" warning but it does charge.
The 300w charger that comes with the Legion 5 is massive, so it's a nice option to be able to use a smaller and lighter charger for work.
It does not provide enough power for gaming however.
What about video editing?
Is there a thin keyboard cover we can buy for this? Just concerned about dust and grit getting stuck in the keyboard.
I've ordered the Legion 5 (non pro) with a 5800h/16Gb/3070 (130w). Pretty much same specs as the Legion 5 Pro version I missed out on. I couldn't be bothered to wait for the Pro to come back in stock seeing as some here have been given dates months away.
Not too fussed on missing out on a 10w more powerful 3070 and the higher res screen. It should be more than plenty for what I need. The screen being 1080p is fine for me as it will mean I will have more GPU headroom to play with. It's still 165Hz, 3ms, 100% srgb and Gsync/Freesync so that's a bonus.
Hopefully it'll be here tomorrow to have a play with on my day off!
Is everything the same apart from display and GPU wattage?
You can order it again.
Edit - Looks like can order the stingray white now as well as the storm grey.
Well that sucks. Despite having notification setup. Looks like no 3070 model![]()
Yeah looks like they went out of stock again this morning. Might be worth keeping an eye on it though.
