lga change makes sense.
almost same pin count as Alder Lake 1700 socket. Imagine if Intel and AMD agree on common cooler mounting points for once?
You madman!
What's the ETA for these?
This year or 2022?
Later in 2022.
"Zen 4 isn't due until the fall of 2022, and a lot can happen between now and then."
AMD Zen 4 may be a long way off but possible specs are coming thick and fast | PC Gamer
So in other words at least a year give or take.
MLID said this too, the reason for the switch to LGAWasn't there a rumour saying it consumes between 120W~170W:
https://www.tomshardware.com/uk/news/amd-zen-4-am5-raphael-cpu-potential-specs
With a minimum 20% IPC gain and 50% more cores 120 to 170 Watts is with in that "+50% PPW"
I am a bit concerned though! Currently the Ryzen 9 5950X is a 105W TDP CPU with 16 cores. 120W would be sort of fine as you get 50% more cores,but 170W would imply power/core has risen!
So I suspect the 50% performance/watt increase will be a lower clocked 120W TDP model compared to the 105W Ryzen 9 5950X(there is also a 65W TDP 12 Core Ryzen 9 5900 too).
For the wattage, is it possible that the AM5 and the implementation Zen4 rumours are combining somehow?
Designing AM5 high-end to be 170W, or even making a 24 core monster etc. and expecting certain boards to handle that, doesn't necessarily mean that 8 core or even 12 core will be anywhere close to that.
My £160 board has a 12+2 Phase VRM, a good one, stressed it struggles to get to 60c.
Even mid range Boards like mine have completely overbuilt VRMs, they can handle 170 watts easily, its the PGA socket that can't.
Mid-range. £160.
I am a bit behind the times
Still on my i5-3570K and Z77 board, which still working nearly 8 year later.
That £80 board is the most expensive board I ever bought (although I guess the board I bought for the Celeron 300A, an Abit BH6 socket 7 - which at the time was £75 - would trump that with inflation).
Before that - certainly in the CD2 era - I used to just get £40 boards or so and £50 or so CPUs, clock them to within an inch of their life and call it a day.
Back then I would only upgrade if I could get twice the performance for the same price.
That's not going to happen any more.
However, I guess spread over 8 years it is not that bad.
When my current PC eventually breaks, I will have to face the reality of modern prices.
For one i think the high end of that prediction is AVX-512.
But ignoring that, a 24 core 48 thread CPU with a massive IPC i'm not even slightly worried at 170 Watts, Intel have churned out CPU's with less cores than that running at 400 Watts, a 12 core Zen 4 is going to be sub 100 Watt's.
I mean Christ think about this for a minute.![]()
I am quite biased as I am a SFF PC fan! I just hope the "peasant" 12 core has a 65W version.
Put it in ECO mode![]()
And then another year to actually be able to have your orders filled.
This is untrue, isn't it. The current CPU supplies are way higher than what the market needs, hence all the retailers offer as many Ryzens as you would wish.
It remains a mystery what AMD is so not serious and completely fails with the GPUs supplies, though.
170-watt is perhaps Threadripper-class or fake information.
Well since CPUs are near indestructible, the question is where would a find a reliable LGA1155 board in 2021+?Or just buy a cheap part second hand to get it back up and running again?![]()
