Imaging? I just install, restart and 20 seconds later I'm back to what I was doing![]()
On one PC I couldn't get rid of the "restart to update" (on power button) notice when I updated to 21H1 via Windows update; and would "hang" on search for updates.
Had to uninstall 21H1 in the end and reinstall fully with the update assistant. Boring !!
^ I've had exactly the same problem on one out of two machines. None of the usual tricks to clear the update cache worked, so restored back to last night's Macrium image and will try again another time.
After creating a restore point and Macrium image, I installed the above update through Windows Update again. This time everything went fine.
Feeling brave, I decided to also install the latest Cumulative Update preview, KB5003212, which also installed fine - albeit slowly.
I uninstalled 20H1 after MS installed a weather app I could not get rid of.
No matter what I tried, it was always showing on my task bar.
You can right click anywhere on the taskbar and select News & Interests > Turn Off. How dare these baskets make life so difficult...![]()
You assume they didn't try that - I can untick the option to show the Windows Welcome screen but it will still pop up again at random whenever it feels like, etc.
