A CD bay?Just get one of the ones that fits in the CD bay, be reet'..
A CD bay?![]()
Is anyone going to try to upgrade to the 3080 ti on launch day ?
Whats the deal with the FE rules (1 per customer)?
If i have bought a 3060ti in the past, would i be able to get a different card (3070 or 3080 for example)?
I can't think that the performance uplift from my 3080 would make it even remotely worth it.
Currently waiting on my 3090 FE to arrive, sometime in the next 2 hours. Hesitant to put it into current PC (replacing my 1080 Ti) as the PSU is 8 years old at this point and I'm not sure where I put all the modular cables... Will be buying the rest of the nw PC next week so will just try to be strong. Also I'm not playing anything right now that needs the 3090...
/Side note - Anybody's FE card coil whine getting better? My cards seems to be staying the same or even getting worseI often play games with volume turned down, and all I can hear is the dam whine!
I do find it gets better after maybe an 45m~ gaming. But still present.
How long you had yours?Mine's improved LOADS since I got it. It was pretty bad under load with a loud buzz. It's hardly audible now I'd say.
Haha, yea I did wonder if age/loud music/etc 'damaged' or reduced hearing would 'benefit' by not hearing high pitched squeaks and whines.Mine doesn't whine but I'm usually at 4k and capped at 60 or got the VR goggles on which would mask it. Possibly my ears are broken though, decades of rock music and motorbikes can do that so I've heard. Or haven't.
It maybe a slight CPU bottleneck with the 2700X especially if your running really high fps.Installed the 3090FE, it's actually not quite as big as I thought it would be, slim chance I could've got away without removing the HDD shelf but I reckon it would have gouged/scraped the end of the card.
Just done some quick testing and got a weird scenario, I'm not hitting 100% utilisation on either GPU or CPU? Doom Eternal, just loading up a save is running about 80-90% GPU, 50-65% CPU (highest single thread around 75%).
Vsync is off and the framerate will go a lot higher in the menu, so it's not being capped. VRAM and RAM both well within limits.
This makes no sense to me, surely one of the GPU or CPU should be maxed out if I'm running at uncapped framerate? Anyone seen something like this, could it be the bus is saturated (PCIE 3.0 16x) and hence the card can't be fully utilised?
To be honest before testing I was half expecting a CPU limitation (2700X), but the stats from Afterburner don't support that. Doom Eternal seems incredibly good spreading the load over 16 threads, probably due to Vulkan.
