Fidelity Super Resolution in 2021
Looks like nexus and wrinkly are making their way through all the threads talking about DLSS,ray tracing and cyberpunk.... like a modern day Doink and Dink tag team partnership. Very entertaining.:D
Took screenshots of the video at 1440P for comparison.
4K FSR 6800XT Scene 3 Zoomed in
The zoomed in shot looks good enough for me. Hardly any difference between 4K and FSR Ultra Quality. Very nice indeed.
The 1060 video they showed at the end on the announcement is pretty bad though so not sure what is going on there. Maybe poor quality capture making everything looks blurry compared to the initial 6800XT video.
Thanks for sharing, these are the first reasonable quality pictures I've seen. :)
I just hope they get a salary for it. :D
Shock, amd release a dlss competitor and there is talk about dlss!!!! :D :cry:
Are you stalking me again? :confused:
If you had bothered to read, @LtMatt brought up DLSS and RT. I just infilled some detail.
Is it a competitor though if nvidia cards can also use it? Just another option more than anything.
True that, suppose it will be a bit like free vs g sync i.e. each will have its strengths and weaknesses.
Definitely the more options, the better though!
Wish we wouldnt get pics of "4k" youtube all the time, utube compression sucks, if you want to compare details then find a uncompressed source if possible please. Also its just a demo, i wouldnt put stock in something whipped up for a dew seconds of show time and then put on youtube.
Here's an interesting post I found on Reddit.
It suggest that 90% of owners with RTX capable hardware don't even use Ray Tracing or DLSS.
That shows you how unimportant Ray Tracing is to gamers right now.
Well, i'm one of them.... i suspected as much, its why i don't get the hype about all this.
The Nvidia 'fans' obviously used that to try and make FSR look bad but if you look at it without bias we can see the quality appears very acceptable and a worthy competitor to DLSS. If there is a slight blur, that is no different to what I've seen with DLSS at 1440P on my 3080FE.
Coming back to this, the Ultra Quality looks good to me from those screenshots. However, I'll need to actually see it for myself before i can truly give my opinion.
Truth be told, I can't see myself ever using it to be honest with a 6900 XT due to the grunt it has, but for lower end GPUs it could be excellent indeed if the quality is decent.
Ah but you're an AMD Schill... Oh you're using a 2070, Damn!
They both look good to me Bug tbf, i can see a bit of a colour difference though. :)
There is a sharpening difference as well, look again, you know what that is? FedelityFX. Its in Reshade now so you can use it on Nvidia GPU's.
Cool, I didn't know that.
If you could make it so you drag a slider over the combined images I'm sure it would be easier to see a difference.
I don't know how to do that but will look into it later, right now i'm off for my dinner.
